HMMOD_nodegetactive()
Retrieves the activity status of a node.
int HMMOD_nodegetactive(void * nodeptr);
HyperMesh hmmodlib Function
nodeptr
The pointer to an node.
0, if the node is inactive.
1, if the node is active.
None.
