config animation
Set animation capture options to be used by all animation commands.
config animation <name>=<value>
Arguments
<name>=<value>
Define the following animation settings:
dimension
Select percent or pixels. Default = pixels.
height
Select current (height of the active window/page) or enter a specific value for the <output height>. Default = current.
quality
Enter a value between 1-100 for the animation quality. Default = 70.
type
Select a file type. Options include:
  • AMF
  • AVI (default)
  • BMP
  • GIF
  • JPEG
  • PNG
  • TIFF
width
Select current (width of the active window/page) or enter a specific value for the <output height>. Default = current.
Define the animation configuration options:
config animation dimension=percent height=current quality=70 type=PNG width=current
