config resultmathtemplate
Set the result math template.
config resultmathtemplate <template name>
Arguments
<template name>
Select a template from the following options:
  • Advanced
  • Composite
  • None
  • NVH
  • Standard
Select the Composit result math template:
config resultmathtemplate Composite
