config model
Set model configuration options.
config model h3d <name>=<value>
Arguments
h3d
Set H3D export options.
allmodels=<true/false>
Default=false
animation=<true/false>
Default=true
compressionloss=<value>
Default=0.01
compressoutput=<true/false>
Default=false.
entityattributes=<true/false>
Default=true
html=<true/false>
Default=false
includemaskedelements=<true/false>
Default=false
includesets=<true/false>
Default=true
previewimage=<true/false>
Default=true
results=<true/false>
Default=true
viewattributes=<true/false>
Default=true
Define the model configuration options:
config model h3d allmodels=true animation=false compressionloss=0.01 compressoutput=true entityattributes=true html=false includemaskedelements=true includesets=true previewimage=true results=true viewattributes=false
