config parameterizedsession
Set report template options.
config parameterizedsession options <name>=<value>
Arguments
options
Set default report template options.
autofitx=<on/off>
on locks the x axis of the current plot so that it does not change as new plots are overlaid. Default=on.
autofity=<on/off>
on locks the y axis of the current plot so that it does not change as new plots are overlaid. Default=on.
autoplacenotes=<on/off>
Automatically fits any notes you add to the window. Default=off.
usereportcolors=<on/off>
on applies line colors, line styles, symbol colors, and symbol styles based on the report template. Default=on.
config parameterizedsession options autofitx=on autofity=on autoplacenotes=on usereportcolors=on
