::SetState
This command will enable or disable the list collector widget based on the input value.
::model::mdlListCollector::SetState argFrm argState
MotionView Tcl
argFrm
We need to pass the path of the list collector which needs to be enabled or disabled as the above argument.
argState
We need to pass either true or false to this argument to enable or disable the list collector widget.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity frchandle ActionReactionForce frc_0 "\"Force\"" "SC_ROT" "" "B_Ground" "" "POINT" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set types "{POINT Point align_pt1} {VECTOR Vector align_vec1}"
set list_col [::model::mdlListCollector $colFrm.lcol frchandle "align_meth1" "$types" -references { POINT VECTOR }]
pack $list_col
client ReleaseHandle
mod ReleaseHandle
frchandle ReleaseHandle
::model::mdlListCollector::SetState $list_col false
On successful execution of the command, the list collector will be enabled or disabled.
