::GetCurrentSelectionVarname
This command will be used to get the varname of the entity to which the collector is resolved.
::model::mdlTempCollector::GetCurrentSelectionVarname argFrm
MotionView Tcl
argFrm
We need to pass the path of the mdlTempCollector in the above argument, for which we need to get the varname.
set selected_point ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set point_col [::model::mdlTempCollector $colFrm.ptcol ::selected_point "Point" "Point" ]
pack $point_col
# Resolve the collector to the Ground Body
::model::mdlTempCollector::GetCurrentSelectionVarname $point_col
On successful execution of the command, if the mdlTempCollector is resolved then it will return the varname of the resolved entity or else it returns a blank.
