pltICurve Bridge
Applies a bridge edit to the curve.
pltICurve_handle Bridge from_val, to_val, orientation, interpolate
HyperWorks Tcl Modify
This method only applies the edit. Call the Recalculate method on the parent plot object to update the data.
- from_val
- The minimum value of the range to be bridged.
- to_val
- The maximum value of the range to be bridged.
- orientation
- The orientation of the edit. Can be "horizontal" or "vertical". Sorts by the x-axis ("x"), y-axis ("y") or none (blank, "").
- interpolate
            - True
- Create new data points at from_val and to_val (using linear interpolation) if they are not already there.
- False
- Do not create new data points at from_val and to_val.
Returns success or an error code.
