pltICurve HighlightRangeByIndex
Highlights between two indices.
pltICurve_handle HighlightRangeByIndex from_index, to_index, marker
HyperWorks Tcl Modify
This command highlights between two indices by putting lines at the two indices and highlighting the part of the curve between the two lines. This is different from HighlightRangeByValue in that it measures between the two indices rather than the two values.
- from_index
- Selected from all of the points that comprise the curve, a number representing the index (position) that you want to be the minimum index.
- to_index
- Selected from all of the points that comprise the curve, a number representing the index (position) that you want to be the maximum index.
- marker
- Type of marker that you want to use to highlight. - modify_horizontal
- Which takes the horizontal range, making vertical lines
- modify_vertical
- Which takes the vertical range, making horizontal lines
- statistics
- Taking a statistical range
- none
- Or clear, which clears the highlighting completely.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetCurveHandle c1 1
c1 HighlightRangeByIndex 12 20 modify_horizontal;Errors
Keywords
HyperWorks
Tcl
Cursor
Modify
