pltIEdit GetInterpolate
Gets the interpolation state of the edit.
pltIEdit_handle GetInterpolate
HyperWorks Tcl Query
Returns true or false.
None.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
ON THIS PAGE
None.
ON THIS PAGE
