pltIEdit GetName
Gets the name of the edit.
pltIEdit_handle GetName
HyperWorks Tcl Query
Returns the name of the edit.
None.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
ON THIS PAGE
None.
ON THIS PAGE
