pltIPlotManager PasteMacro
Pastes a macro.
pltIPlotManager_handle PasteMacro idx
HyperWorks Tcl Modify
This command pastes the previously copied or cut macro(s). A macro is a user-defined function that depends on a curve in the plot. For example, a macro could be made that takes the derivative of a curve.
idx
The index (position) of where in the macro list that you want to paste the macro(s). If no index is given, the command pastes the macro at the beginning of the list (the first position). If an index is given, the command pastes the macro in the user-input index and moves the list down one position if it is at or below that index.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm CopyMacro 1;
pm PasteMacro 2;
Keywords
HyperWorks
Tcl
Macro
Modify
