pltIPlotManager RemoveMacro
Removes a macro.
pltIPlotManager_handle RemoveMacro idx
HyperWorks Tcl Modify
This command removes the macro at the input index. A macro is a user-defined function that depends on a curve in the plot. For example, a macro could be made that takes the derivative of a curve.
idx
The index (position) of where the macro that is to be removed is located.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm RemoveMacro 2;
Keywords
HyperWorks
Tcl
Macro
Modify
