pulIMacro CopyParameter
Copies the given parameter for the current macro.
pulIMacro CopyParameter index
HyperWorks Tcl Modify
This command copies the parameter with the given index.
index
The index of the parameter to be copied. Must be a positive integer.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro AddParameter "Parameter 1"
macro CopyParameter 1
macro PasteParameter 1
Returns 3 = HW_InvalidHandle if there is an invalid macro handle.
Returns 4 if index is less than 0 or greater than the number of parameters in the current macro.
Keywords
HyperWorks
Macro
Tcl
