Page Break
Add a page break to the report.
  1. Right-click at the Report or Chapter level and select Add > Items > Break.
  2. Below are the properties associated with the Break entity.
    1. Name: You change the name property of the break item.
    2. Orientation: Select the page break type. The page breaks also change the orientation of the following pages in the exported report.
      Figure 3.
      Restriction: Section breaks are not supported on Linux.
