Word Document
Add pages from a Word document to the report.
  1. Right-click at the Report or Chapter level and select Add > Items > Word Document.
  2. Below are the properties associated with the Word Document entity.
    1. Name: You change the name property of the Word document item.
      Note: Once you select a Word file, the Word entity name is replaced with the selected file name.
    2. File Path: Select a Word file using the file browser option.
