Table of Reference
Add a table of reference to the report.
  1. Right-click Report and select Add > Items > Table of Reference
    Note: Report allows you to add only one Table of Reference for the session.
  2. Once Table of Reference is added, a chapter titled Table of Reference is added to the tree. Also, a table entity titled Table of Reference is added under it.
  3. Below are the properties associated with the Table entity.
    1. Name: Edit the name property of the reference table entity.
    2. Caption: Provide a caption for the table entity. This caption is visible in the exported Document report.
    3. Source: Select the data input type for the table entity. Available options are:
      1. Data
      2. External CSV/XLSX
      3. TableView Window
      4. HyperMesh Table
      5. Matrix Browser Table
    Advanced
  4. Location of Caption: Select the caption location from the list. These are standard locations as present in Microsoft Word. Table caption locations can be:
    Figure 3.
    1. Below Table, or
    2. Above Table
  5. Auto Split Table: Provides the function to split up tables automatically based on the space available in the slide or page.
    Adding a reference
  6. To add a reference, select the required text and right-click Insert Table of Reference.
    Figure 4.
  7. A table of reference option is displayed. Select the required cell from the table and click OK. This adds a reference for the selected text item to the cell item in the table.
    Figure 5.
    Adding a Cross Reference
  8. To add a cross reference, select the required text and right-click Add Cross Reference.
    Figure 6.
  9. A Select Item to Cross Reference dialog opens. You can select the required entity from the table and click OK.
    Figure 7.
