Text File
Add a text file to the report.
  1. Right-click at the Report or Chapter level and select Add > Items > Text File.
  2. Below are the properties associated with the Text File entity.
    1. Name: You change the name property of the text file item.
    2. File Path: Select a text file using the file browser option.
      Note: The text file entity imports the data from the selected text file and inserts it into the exported report. The imported text is assigned default font in the report.
