Lines
Use the tool to create curve graphics from a set of selected
points or nodes. The generated curve graphics can be used to setup 2D
rigid to rigid contact or advanced joints, such as point to curve or
curve to curve joints. Based on the selected set of points or nodes
belonging to a file graphic or CAD graphic, this tool creates a 3D
cartesian curve and a curve graphic.
Create Lines
From the Model ribbon, Geometry tool set, click the Lines
tool.
The Lines panel is displayed.
Click the System collector to identify the system or
container into which the curve graphics will be created.
The Model label means that the graphics will be created in the main
model.
Click the Body collector and
select a body from the modeling window, or double click
the Body collector to open the Model Tree (from which the desired body can be selected).
Specify a label for the curve and the curve graphics that will be automatically
created.
Use the drop-down menu to leave the ends of the curve open or generate a closed
curve by automatically joining the first and last point/node.
Click the Point/Node collector and choose points and
nodes from the modeling windowor the Model Tree.
Highlight the points or nodes that will make up the curve.
Tip:
- To select all the points/nodes, click Select
All
- To deselect all points/nodes, click Select
None
- You can also reverse the selection status of the components in the
list by clicking Reverse Selection
Click Create to create the curve and the graphics.
