FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
MotionView works with a HyperWorks neutral file called H3D to represent the flexible body. This compact file format stores the necessary information for
visualizing the flexbody in the pre-processing window and the modes and interface nodes in the post-processing window.
It also stores the modal and nodal information.
MotionView models solved in MotionSolve or Adams can be animated in HyperView. In addition, the plots for these models can also be viewed in HyperGraph.
The Fatigue Prep custom wizard generates ADAMS output files from a flexbody transient run, which can then be used in nCODE
Fatigue software. Finite element fatigue requires that flexbody mode shapes be an nCODE FES file, and the flexbody modal
participation factors be "n" number of DAC files, where each DAC file contains the time history of a single mode's modal
participation factor.
nCODE fatigue software requires that the stress modes be represented in their FES file format. MotionView allows you to convert these modes from an H3D flexbody file to the nCODE FES file.
nCODE fatigue software requires that each time history of modal participation factors be represented in the DAC file format,
one file per time history. MotionView provides the conversion option from the ADAMS ASCII file to "n" number of DAC files, where "n" is the number of modes
within the flexbody. MotionView modifies the base name accordingly so that unique filenames result.
Fatigue Prep Overview
The Fatigue Prep custom wizard generates ADAMS output files from a flexbody transient run, which can then be used in nCODE Fatigue software. Finite element fatigue requires that flexbody mode shapes be an nCODE FES file, and the flexbody modal participation factors be "n" number of DAC files, where each DAC file contains the time history of a single mode's modal participation factor.
Preparing nCODE FES and ASC Files from H3D Flexbody Files
Preparing nCODE DAC Files from ADAMS RES Files
nCODE fatigue software requires that each time history of modal participation factors be represented in the DAC file format, one file per time history. MotionView provides the conversion option from the ADAMS ASCII file to "n" number of DAC files, where "n" is the number of modes within the flexbody. MotionView modifies the base name accordingly so that unique filenames result.
