Apply Style
Select and apply attributes of the current plot to either every plot on every page or to every plot on the current page.
Right-click on the plot window context menu and select HG Apply Style.
From the drop-down menu under Pre Selection, select Current Page, All Pages or Last Selection.
- Current Page
 - Applies the attributes of the current plot to the other plots on the current page.
 - All Pages
 - Applies the attributes of the current plot to the plots on every page.
 - Last Selection
 - Applies the attributes of the current plot to the previously selected curve.
The following attributes can be selected from the dialog. Place a check mark in the box to select the attribute that you want to apply. Upon opening the dialog, attributes that already have a check mark next to them are selected by default.
- Plot
 - Background color
Frame color
Gridline color
Zero line color
Bar gap (Disabled if the current plot is not a bar chart).
Bar stacking (Disabled if the current plot is not a bar chart).
Complex axes (Disabled if the current plot is not a complex plot).
+/- 180 Phase constraining (Disabled if the current plot is not a complex plot).
 - Legend
 - Font
Border thickness
Leader position
Color
Location
Visibility
 - Header/Footer
 - Primary font
Secondary font
Tertiary font
Color
Alignment
Visibility
 - Axes
 - Apply to: Primary horizontal, Primary vertical, All
                                secondary
Attributes: Label, Label font, Tic font, Color
Formatting: Axis scaling, Min, Max, Tic method, Increment, Number of tics, Number of grids, Numeric format, Numeric precision, Autofitting, Fit to range
 - Curves
 - Line style
Line thickness
Line color
Symbol
Symbol color
Symbol increment
Bar fill pattern - Disabled if the current plot is not a bar chart.
 - Notes
 - Font
Border thickness
Color
Alignment
 - Page Title
 - Font
Visibility
 - Selects all the options on the dialog.
 - Deselects all the options on the dialog.
 - Reverses the selection for each option. For example, a selected check box becomes unselected.
 - Apply
 - Applies the selected options to the current page or all pages (whichever you have selected).
 - OK
 - Applies the selected options to the current page or all pages (whichever you have selected) and closes the dialog.
 - Close
 - Closes the dialog.
