Use Math as a Data Source
- From the Bar Chart Define panel, select .
- Define the vector using the curve calculator to create a mathematical expression.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
ON THIS PAGE
ON THIS PAGE
