Change Note Attributes
- From the ribbon, click the Notes tool or exit the current tool/panel.
                Right-click on the note to be edited. From the context menu, select
                        Edit to display the floating Entity Editor.
Figure 1. Notes context menu
Figure 2. Notes - Entity Editor - From the floating Entity Editor, select the attribute(s) you want to change. You change a note's visibility, font settings, text, and border thickness and color. These attributes can also be changed in the Media Browser.
