View new features for HyperWorks 2022.
Explore the GeoD user interface.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks applications.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
Creates a 4x4 horizontal or vertical page layout that displays a series of frames for up to four media files at specified time offsets.
ON THIS PAGE
ON THIS PAGE
