Create Curves
- From the Marker Tracing panel, click Create Curves.
 - From the Place on drop-down menu, select New Plot, Preview Plot, or Existing Plot to place curves on.
 - Click OK to generate a curve in HyperGraph 2D from the traced marker.
 - Used Defined Unit is disabled and unchecked if a master unit measure has not been defined in the Measures panel.
 - If a master unit measure has been defined and Use Tracking is checked in the Measures panel, then Use Defined Unit is enabled and checked by default.
