Supported File Types
Please see Supported File Types for a list of file types supported in HyperWorks.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks applications.
The MediaView Media Browser is located on the tab area sidebar and allows you to view and edit media files.
Control the view and display of your media file in the modeling window.
Use the Measures panel to create a vector across any portion of a static or movie image and display the value of the vector in pixels.
For AVI files, MediaView supports the following compression formats by default: MJPEG/MJPG, CVID (cinepak), uncompressed 24-bit color, and RLE 8-bit color.
MediaView can open video files which were unreadable in previous versions by using external programs as format translators, which create an AVI file using the MJPEG codec.
The Altair Movie Format (AMF) specification is a digital video format.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Compare video frames or overlay frames with other videos or images to watch them in flips.
