Create Generic Structural Elements
Use the Generic tool to collect elements and free body sections in designpoints.
From the Certification ribbon, click the Generic
tool.
Figure 1. -
Select elements or freebody sections to collect.
You can select any combination of elements and they will be collected into a single designpoint.
If you select multiple freebody sections, a designpoint is created for each.
On the guide bar, click
to select a Split by
option. In the case of a Generic structural element, the split is directly
done on the element selected. The designpoint is created based on the
element’s property or component if split is used. - Optional:
Select a destination DesignPointSet to hold newly created designpoints.
If no set is selected, a new one is created with config Generic.
If you enter this menu from the Certification Browser context menu using Auto DDP, the selector is pre-populated with the selected designpointset.
- Specify a structuralproperty entity to assign.
On the guide bar, click one of the following:
- Save changes and stay in the tool.
- Save changes and close the tool.
