mat100 (hexa)
Creates hexa element with plot elements projecting and connecting to the surrounding shell elements. This realization does not use the shell thickness to calculate the hexa offset, therefore the hexa will project and be touching the shell elements.
The dyna mat100 (hexa) exists in exactly the same configuration with a HC hexa spotweld.
This is in order to keep the realization names from HyperCrash.
