HyperWorks
HyperWorks
2022
  1. Home
  2. Connectors
  3. Realizations
    View details for different types of realizations.
  4. Fastener Connector Realization Types
    A list of realization types that can be specified for fastener connectors.
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Squeak and Rattle Director
  • Geomechanics Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022
HyperWorks
  • What's New
    View new features for HyperWorks 2022.
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
    • Open the Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Define Connector Controls
      Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
    • Create and Realize Connectors
      Use the tools in the Create tool set to create connectors, assign controls, and realize.
    • FE Absorb Connectors
      Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
    • Realizations
      • Point Connector Realization Types
        A list of realization types that can be specified for point connectors.
      • Fastener Connector Realization Types
        • bolt (2 cylinder rigid)
        • bolt (BEAM44)
        • bolt (CBAR)
        • bolt (LINK10)
        • bolt (b31)
        • bolt (collapse Rigid)
        • bolt (cylinder bar)
        • bolt (cylinder rigid)
        • bolt (cylinder spring)
        • bolt (general)
        • bolt (Metal Clip)
        • bolt (spider)
        • bolt (step hole)
        • bolt (threaded step hole)
        • bolt (washer 1 alt) LINK10
        • bolt (washer 1) BEAM44
        • bolt (washer 1) LINK10
        • bolt (washer 1) cbar
        • bolt (washer 1)
        • bolt (washer 2 alt)
        • bolt (washer 2) LINK10
        • bolt (washer 2)
        • clip (washer nodes)
        • clip
        • ConNode (spider)
        • HC cylinder rigid bolt
        • HC cylinder spring bolt
        • hinge (b31)
        • hinge
        • RgdBody (spider)
        • RgdBody (spider + washer)
        • wagonwheel
      • Line Connector Realization Types
        A list of realization types that can be specified for line connectors.
      • Area Connector Realization Types
        A list of realization types that can be specified for area connectors.
    • Element Organization
      Organize elements into connector groups.
    • FE Configuration File
      The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
    • Attachments and Connectors
      Attachments are an entity to facilitate the ease of joining subsystems.
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
    Explore the GeoD user interface.
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022
  1. Home
  2. Connectors
  3. Realizations
  • What's New
  • Get Started
  • Video Tutorials
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Marine
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  • bolt (BEAM44)
  • bolt (CBAR)
  • bolt (LINK10)
  • bolt (b31)
  • bolt (general)
  • bolt (Metal Clip)
  • bolt (spider)
  • bolt (step hole)
  • bolt (washer 1)
  • bolt (washer 2)
  • clip
  • ConNode (spider)
  • hinge (b31)
  • hinge
  • RgdBody (spider)
  • wagonwheel
