Equations
Equation entities contain mathematical equations that define more complex loads. They are used to define linear constraints in local and global coordinate systems.
Every equation must be organized into one load collector, and therefore are mutually exclusive to a load collector.
Equations are displayed as lines between the dependent node and the independent node(s) with EQ displayed at the dependent node of the equation in the modeling window.
Equations are used in Nastran as MPC (Multipoint Constraint Equation) or in Abaqus as *equation.
Equations are organized into load collectors.
Abaqus Cards
| Card | Description |
| *EQUATION | Define linear multi-point constraints. Note: Explicit node IDs are supported.
                    Node sets are not supported.
Equations are considered as loads and therefore, they are collected in load collectors. Upon export, they write to the bulk data portion of the Abaqus deck.  |
ANSYS Cards
| CE | Defines a constraint equation relating to degrees of freedom. |
LS-DYNA Cards
Several load types cause three cards to be output for x, y, and z components. During input, these are grouped into one load. Loads cannot be applied to sets, components, or boxes. Load curves are input and output. Use the Card Editor to select load curves. Unless mentioned in the Notes column, load cards cannot be edited.
| *CONSTRAINED_LINEAR | Define linear constraint equations between displacements and rotations, which can be defined in a local coordinate system. |
| *CONSTRAINED_LINEAR_GLOBAL | Define linear constraint equations between displacements and rotations, which can be defined in global coordinate systems. |
Nastran Cards
| MPC | Defines a multipoint constraint equation of the form. Note: Individual weight
                    factors can be created on the nodes of an MPC equation using the update
                    functionality in the Equations panel.
OptiStruct Cards
              form. Note: Bulk Data
                    Entry
Permas Cards
| $MPC GENERAL | General linear constraint equation. |
