Drag Geometry
Drag surfaces, nodes, or lines along their normal direction, a vector, or another line.
A drag preview for FE geometry solids is not supported at this time
Auto-Trim
Use the auto-trim
option in the microdialog when dragging nodes and lines.
While dragging lines or nodes, if a continuous surface or mesh is intersected and this option is ON, the newly created surfaces are trimmed at the intersection. The auto-trim option works for both geometry intersecting geometry and mesh. It also works for FE topology intersecting FE topology.
Figure 2. Surfaces intersecting with surfaces
Figure 3. Surfaces intersecting with mesh
Figure 4.
Figure 5.
![]() Figure 6. Input lines |
![]() Figure 7. Stitch trimmed surfaces ON |
![]() Figure 8. Stitch trimmed surfaces OFF |
to define additional options.
