Set Up Design Space Libraries
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
View new features for HyperWorks 2022.
Voxel meshing fills an enclosed volume with voxels (hexas) of a predefined size.
Edit and position nondesign parts or subsystems in your design space.
The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
Design spaces can also be connected to structural elements using tie-based contacts.
View tutorials for design space workflows.
Explore the GeoD user interface.
ON THIS PAGE
ON THIS PAGE
