Edit and Position Primitives
Edit and position nondesign parts or subsystems in your design space.
Before you can edit non-design parts or sub-systems, you must Set Up Design Space Libraries. Alternatively, you can import a part or sub-system.
View new features for HyperWorks 2022.
Voxel meshing fills an enclosed volume with voxels (hexas) of a predefined size.
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
Design spaces can also be connected to structural elements using tie-based contacts.
View tutorials for design space workflows.
Explore the GeoD user interface.
ON THIS PAGE
The voxel mesher will automatically fill voids, however, for large openings in the include and/or exclude package space, it is expected that the model is prepared beforehand. It is therefore recommended that you use the Hole/Gap Fill tool to generate the correct design space.
ON THIS PAGE
