Transform Elements
Use the Transformation Tool to translate, scale, reflect or rotate elements with multiple numbers of copies, including properties and loads, attached to them.
View new features for HyperWorks 2022.
Explore the HyperWorks user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools, panels, and browsers that are available from the ribbons or from the Utility Browser, as well as create entities and solver cards.
Select and deselect entities to modify with other HyperWorks tools. Selected entities are outlined to indicate their selection state.
Translate, rotate, and align the model.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities in HyperWorks.
Learn the basics of working with entities.
Learn how to work with entities using the Entity Editor.
Define the mandatory, default value, and/or hidden state settings for entity attributes.
Use the tools in the Home ribbon group menu to transform, mirror/reflect, and adjust the dimensions of entities.
Use the Mirror tool to mirror/reflect selected entities across a symmetry plane.
Use the Scale tool to increase or decrease an entity's dimensions in you model
Add metadata to all types of entities. The added metadata can be saved to an *.hm file.
Undo and redo actions performed in HyperWorks.
Default keyboard shortcuts and mouse controls.
Explore the GeoD user interface.
ON THIS PAGE
ON THIS PAGE
