SolverDiffeq
Class SolverDiffeq()
SolverDiffeq(parent='MODEL', name='SolverDiffeq_n', label='SolverDiffeq_n',
active=True, static_hold=False, implicit=False, ic=0, ic_dot=0))
Creates a solver differential equation.
Keyword Arguments
Argument Data Type Description Default
name String The variable name. SolverDiffeq_n, for next available integer n.
label String The descriptive label. SolverDiffeq_n, for next available integer n.
parent Object The parent. MODEL
active Boolean Used to activate or deactivate this entity. True
static_hold Boolean Set STATIC_HOLD if the state of the differential equation is not permitted to change during static and quasi:static analysis of the solver. Otherwise, leave blank by including two commas to hold the space. False
implicit Boolean Specifies whether the differential equation is of type implicit or explicit. False
ic Double The initial condition of the differential equation. 0
ic_dot Double The initial condition for the first derivative of the user defined variable. This is optional and is usually used in conjunction with an implicit variable. 0
user Bool Use user defined properties, if true. False
usr_sub Function The expression passed to the user dll. When using solver expressions, Templex syntax (within ) is used and all variables are enclosed in braces {} and the rest is treated as literal. 'USER()'
local_funcname String The function/subroutine name. 'MOTSUB'
use_local_dll Bool Uses a local function instead of default if True. False
local_dll File The path of the local dll which has the local_funcname. ''
local_func_type Enum The type of the user subroutine. One of DLL, PYTHON or MATLAB. 'DLL'
Instances
value (Nonlinear) : The function expression which describes the differential equation.
Examples
Create a solverdiffeq and modify its property values.
   >>> from hw import mview
   >>> # Create a solver diffeq
   >>> sde = mview.SolverDiffeq()
   >>> sde.implicit
   False
   >>> sde.value.expr = '`DIF1(sde_equation.id) + 8.0 + COS(TIME)`'
   >>> sde.ic_dot = 2
   >>> sde.ic_dot
   2.0
