FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Model Info group contains modules associated with information of the model contents including component summary, connection
statistic, material summary, property summary and more.
Validate group contains modules associated with high level diagnostic information of the model such as model statistics,
mesh quality statistics, model checker summary and more.
Loop through loadcases and components to extract results and images for contours and
notes.
This module allows you to capture the overview of the maximum, minimum, or hotspots of various
result types such as Displacements, Stresses, and Margin of Safety for each
combination of critical components and critical load cases in the model. This
enables you to define and perform any specific use case for each combination of
component and loadcases.
Adding a Loop Results Module
From the Report Ribbon, Add Modules tool group, click and select Loop Results
module.
Note: This module is available for both Document and Presentation
modes.
Below are the properties associated with the Loop Results module:Figure 1.
Note: The Loop Results properties are the same for Document and
Presentation reports.
Under the Loop Results module, you can add
the following Document report items:
Chapter
Text
Table
Page Break
Note: For images inside the loop, the image caption can use some variables
from HyperView. Figure 2.
The supported keywords are $page, $window, $loadcase,
$loadstep, $group, $component, $datacomponent, $datatype, $timestep,
$maxval, $maxid, $minval, $minid, $subcaselabel, $subcase, $componentid,
$binding, $count, $indexi, $indexj, $subcaseid, $loadcaseid,
$loadstepid, $resultvalue and $datalayer.
For a
Presentation report, add a Slide Layout or an Existing Slide under the Loop
Results module.
Name
Enter the title of the result loop.
Model
Select the required page or window from the HyperWorks session.
Note: As results are
present in HyperView and Loop
Results types are possible only in HyperView, solution displays only
those pages or windows that have the HyperView client in the drop-down
selection.
Component Selection
In loop results, it is necessary to select the components that
you want to run and extract results for. You can select the
components using the following options.
Components
Select components for looping using the standard
HyperView component
selection option.
Sets
Select the component sets for looping. Only sets of
pool type User_Set are displayed.
Add Displayed Elements
Select this checkbox to add the entities currently
displayed in the graphics area as a group.
Load Case Selection
Choose Loadcase: Select the load cases to be used for looping.
By default, Active is selected.
Active
Active loadcase in the HyperView window.
Last
Last loadcase in the list of loadcases of the
results file.
Multiple
Activates the Selected Load
Cases option. This option allows you
to select multiple loadcases from the
Select Load Cases
window.
Exclude and Hide Entities
Exclude and Hide Entities: Select the entities that you want to
be excluded from results looping and to be hidden from the
graphics area while capturing the images.
You can select the following entities to exclude and hide:
Sets
Click Entity Selection to
open the Select Sets window and
select the required sets.
Components
select components from the graphics area.
Exclude Entities
Exclude Entity Type
Select the entities in the model to be excluded from
the looping.
These entities will not be hidden from the graphics
area while capturing images.
Entity Selection
You can select following entities to exclude:
Sets- Click
Entity Selection to open
Components - Click
Entity Selection to select
Number of Layers
Select number of layers of adjacent elements to be
excluded in addition to the entities selected
above.
Advanced
Start Loop With
Specify whether the loop is to be started with a
component or load case.
Note: The columns and the
rows in the Interactive Result Table that come up
on loop execution would also be interchanged based
on this selected option.
Overview of each Load Case
Select this checkbox to view the overview for each
load case in the result. Complete overview takes the
current set view of the model on the selected
page/window. Results are shown without the scale
factors.
Export
Export the Loop Results to Document or
Presentation.
Below are the options available in the Export
settings:
All: All of the results are exported.
Above: Results above the defined threshold
value are exported.
Below: Results below the defined threshold
values are exported.
Equal to: Results equal to the defined
threshold value are exported.
Critical: Results that are above the red limit
defined in threshold user interface are exported.
This option is shown only when the thresholds are
defined.
Overview: The overview results for each load
case are exported. This option is shown only when
the overview for each load case option is
selected.
Loop Over Hotspots
Loop over hotspots detected by Report. You have to
enable additional features in Image to use this
feature.
Auto Split Table
Split the interactive result table into smaller
tables based on the maximum rows and columns
specified.
