Standard Views
Captures images of the model in 4 standard views - Isometric, Left, Top and Front views.
From the Report Ribbon, Add Modules tool group, click
and select Standard Views
module.Or
Right-click at the Report or Chapter level and select .- Below are the properties associated with the Standard Views module.
Figure 1. - Name
- Provide the name for the Standard Views module.
- View Type
- Standard
- Creates the four standard views of the model- Isometric, Left, Top and Front.
- Predefined
- Executes a predefined script and attach the output as an
image. Note: You must provide a script file path.
