Import and Export CSV Files
You can import and export comma separated value files (CSV) to and from TableView. There are two ways to access this feature:
Or
View new features for HyperWorks 2022.
Explore the GeoD user interface.
You can load an Excel CSV file into TableView.
Displays the data contained in the selected TableView cell.
Define value-dependent rules and apply them as attributes within the selected cells.
TableView supports overlaying reports for summary tables.
Shows or hides the table column headers and row numbers.
Refreshes the table data.
TableView supports cell math references in a Templex expression, like the support of curve math references in HyperGraph.
From TableView, use the Table Browser to view the current session and all pages and windows it contains in a hierarchical display.
From within a cell, row number, or column header in TableView, right-click to display the following context menu items.
ON THIS PAGE
Or
ON THIS PAGE
