Nastran to ANSYS Conversion Mapping
Materials
表 1. Supported Material Mappings
Nastran ANSYS Convert Parameters
MAT1 MPTEMP/MPDATA E, G, NU, RHO, A, GE, TREF
MATT1 MPTEMP/MPDATA T(E), T(G), T(NU), T(RHO), T(A), T(GE)
MAT2 MATERIAL density
MAT4 MATERIAL density
Elements
表 2. Supported Element Mappings
Nastran ANSYS HM Configuration
CONM2 MASS21 Mass
CELAS1 COMBI14 Spring
CBAR, CBEAM BEAM44 Bar2
CROD LINK8 Rod
CTRIA3, CTRIAR SHELL63 Tria3
CQUAD4, CQUADR, CSHEAR SHELL63 Quad4
CTRIA6 SHELL93 Tria6
CQUAD8 SHELL93 Quad8
CTETRA SOLID45 Tetra4
CTETRA SOLID95 Tetra10
CHEXA SOLID45 Hex8
CHEXA SOLID95 Hex20
CPENTA SOLID45 Penta6
CPENTA SOLID95 Penta15
CGAP CONTACT52 Gap
CBUSH COMBI14 Spring
Properties
表 3. Supported Property Mappings
PBAR, PBARL, PBEAM, PBEAML BEAM44p none, only creates property card with BEAM44p
PBUSH COMBI14p k1 to k6, GE1 to GE6
PELAS COMBI14p k, GE
PGAP CONTACT52p U0, KA, KT, MU1
PROD LINK8p none
PSHELL, PSHEAR (tria3, quad4) SHELL63p Shell Thickness
PSHELL, PSHEAR (tria6, quad8) SHELL93p Shell Thickness
PSOLID (tetra4, penta6, hex8) SOLID45p none
PSOLID (tetra10, penta15, hex20) SOLID95p none
ETType of ANSYS
If the model contains Nastran elements which were mapped to MASS21, LINK8, COMBI14, BEAM44, SHELL63, SHELL93, SOLID45 and SOLID95 elements, respective ETTYPES will be created and assigned to the component. Key options of ETTYPE will not be updated.
Components
If the component collector contains different type of configuration of elements, new components will be created for the respective configurations and those elements will be moved into the new component. ETTYPE, material and realset IDs will be assigned to the new component.
Loads and Boundary Conditions
Loads and boundary conditions will not be converted by using this conversion tool.
