Nastran to Radioss Conversion Mapping
Elements
表 1. Supported Element Mappings
Nastran Radioss
CONM2 /ADMAS
CWELD Mesh less weld
(feabsord, fe realize using HEXA)
CELAS1/CELAS2
CDAMP1/CDAMP2
(0 length)
/SPRING
PLOTEL Plot element
RBAR /RIVET
RBE2/RBE3 /RBODY
RJOINT /RLINK
CBUSH
(When using vector)
/ SPRING3N
CBUSH1D /SPRING2N
CBAR/CBEAM/CBEND BEAM
CROD TRUSS
CONROD TRUSS and /PROP/TRUSS
CTRIA3/CTRIAR
CTRIA6
(Change to 1st order before convert)
/SH3N
CQUAD4, CQUADR, CSHEAR
CQUAD8
(Change to 1st order then convert)
/SHELL
CTETRA4
CTETRA10
/TETRA4
CHEXA8/ CPENTA6
CHEXA20/ CPENTA15
/BRICK
Properties
表 2. Supported Property Mappings
Nastran Radioss
PBAR/PBEAM
(Only single section PBEAM is supported)
/PROP/BEAM
PBUSH /PROP/SPR_GENE
PBUSH1D/PDAMP/PELAS /PROP/SPRING
PROD /PROP/TRUSS
PSHELL/PSHEAR /PROP/SHELL
PSOLID /PROP/SOLID
Materials
表 3. Supported Material Mappings
Nastran Radioss
MAT1 /MAT/ELASTIC
MAT8 /MAT/LAW19
