Engine Files
制約事項: This entity is only valid in the Radioss interface.
Engine Files are used to collect the Radioss Engine Control Cards to define multi-stage simulations.
An Engine File can be made current, so that any Engine Control Cards created thereafter automatically go in the current Engine File.
Export of a Radioss model with the option “Merge Starter and Engine” will only merge the first Engine File within the model.
