Tables
Table entities collect data points.
Abaqus Cards
Card | Description |
*DISTRIBUTION ANGLE | Creates a *Distribution table for angles. 注: Can be referenced in
*Orientation.
A default angle must be provided, which will be used for elements without angle values. |
*DISTRIBUTION DRAPE | Creates a *Distribution table for thickness and angle. 注: Contains both the
angle and thickness, but during export separate *Distribution keywords are
written.
Can be referenced by *Shell Section with composite ply information. A default angle and thickness must be provided, which will be used for elements without thickness and angle values. |
*DISTRIBUTION OFFSET | Creates a *Distribution table for offset. The offset values define the offset
and thickness of elements. 注: Can be referenced by *Shell Section using the
thickness option.
A default offset must be provided, which will be used for elements without offset values. |
*DISTRIBUTION ORIENTATION | Creates a *Distribution table for orientation. The orientation values define
the orientation of elements. 注: Can be referenced by *Orientation.
A default orientation value must be provided, which will be used for elements without orientation values. |
*DISTRIBUTION THICKNESS | Creates a *Distribution table for thickness. The thickness values define the
Can be referenced by *Shell Section using the thickness option. A default thickness value must be provided, which will be used for elements without thickness values. |
*SPECTRUM | Creates a *Spectrum table for *RESPONSE SPECTRUM ANALYSIS. This value can be
defined as a function of spectrum, frequency, and damping. 注: Can be referenced
by *RESPONSE SPECTRUM.
