HyperViewでサポートされるNastran結果
HyperViewでは、NastranのFEMZIP、OP2、XDBおよびH5の各結果ファイルフォーマットをサポートしています。
データ名 | 結果タイプ | Data Type |
1D Element (Forces / Moments)1 | ELEMENT | VECTOR |
Acceleration (Translation / Rotation) | NODE | VECTOR |
Applied (Forces / Moments) | NODE | VECTOR |
Contact (Force / Moment / Traction) | NODE | VECTOR |
Displacement | NODE | VECTOR |
Element (Fluxes / Gradients | ELEMENT | VECTOR |
Grid Point Element (Forces / Moments)2 | ELEMENT | VECTOR |
MPC (Forces / Moments) | NODE | VECTOR |
Rotation | NODE | VECTOR |
SPC (Forces / Moment)6 | NODE | VECTOR |
Summed (Forces / Moments) | NODE | VECTOR |
Velocity (Translation / Rotation) | NODE | VECTOR |
2D Element (Forces / Moments)3 | ELEMENT | TENSOR3-D |TENSOR2-D |
Composite (Stress / Strain) | ELEMENT | TENSOR3-D |TENSOR2-D |
Grid Point Stresses | NODE | TENSOR3-D |TENSOR2-D |
Nonlinear Strain | ELEMENT | TENSOR3-D |TENSOR2-D |
C | ELEMENT | TENSOR3-D |TENSOR2-D |
PSD Stress | ELEMENT | TENSOR3-D |TENSOR2-D |
RMS Stress | ELEMENT | TENSOR3-D |TENSOR2-D |
1D Force: CROD Axial Force CROD Torque CBAR Bending Moment (A1 / A2) CBAR Bending Moment (B1 / B2) CBAR Shear1 CBAR Shear2 CBAR Axial Force CBAR Torque CBEAM Bending Moment (Plane1 A / Plane2 A) CBEAM Bending Moment (Plane1 B / Plane2 B) CBEAM Web Shear (Plane1 A / Plane2 A) CBEAM Web Shear (Plane1 B / Plane2 B) CBEAM Axial Force (A / B) CBEAM Total Torque (A / B) CBEAM Warping Torque (A / B) CBUSH Force (x / y / z) CBUSH Moment (x / y / z) CELAS1 Force CELAS2 Force CGAP Normal x CGAP Shear (v / w / y / z) CGAP Axial u CGAP Slip (v / w) CWELD Bending Moment (Plane1 A / Plane2 A) CWELD Bending Moment (Plane1 B / Plane2 B) CWELD Shear (Plane1 / Plane2) CWELD Axial Force CWELD Torque |
ELEMENT | SCALAR |
1D Nonlinear Stress: CBEAM Equivalent Stress at Point (C1 / C2) CBEAM Equivalent Stress at Point (D1 / D2) CBEAM Equivalent Stress at Point (E1 / E2) CBEAM Equivalent Stress at Point (F1 / F2) CBEAM Long Stress at Point (C1 / C2) CBEAM Long Stress at Point (D1 / D2) CBEAM Long Stress at Point (E1 / E2) CBEAM Long Stress at Point (F1 / F2) |
ELEMENT | SCALAR |
1D Nonlinear Strain CBEAM Effective Creep Strain at Point (C1 / C2) CBEAM Effective Creep Strain at Point (D1 / D2) CBEAM Effective Creep Strain at Point (E1 / E2) CBEAM Effective Creep Strain at Point (F1 / F2) CBEAM Effective Plastic Strain at Point (C1 / C2) CBEAM Effective Plastic Strain at Point (D1 / D2) CBEAM Effective Plastic Strain at Point (E1 / E2) CBEAM Effective Plastic Strain at Point (F1 / F2) CBEAM Total Strain at Point (C1 / C2) CBEAM Total Strain at Point (D1 / D2) CBEAM Total Strain at Point (E1 / E2) CBEAM Total Strain at Point (F1 / F2) |
ELEMENT | SCALAR |
1D Strain CBAR Axial CBAR (SA1 / SA2 / SA3 / SA4) CBAR SA (Maximum / Minimum) CBAR Safety Margin (Compression / Tension) CBAR (SB1 / SB2 / SB3 / SB4) CBAR SB (Maximum / Minimum) CBEAM Long Strain at Point (C1 / C2) CBEAM Long Strain at Point (D1 / D2) CBEAM Long Strain at Point (E1 / E2) CBEAM Long Strain at Point (F1 / F2) CBEAM Margin of Safety (Compression1 / Compression2) CBEAM Margin of Safety (Tension1 / Tension2) CBEAM Maximum (Strain1 / Strain2) CBEAM Minimum (Strain1 / Strain2) CELAS Strain CROD Axial (Strain / Safety Margin) CROD Torsional (Strain / Safety Margin) CWELD Axial Strain CWELD Max Shear Strain CWELD Max (Strain A / Strain B) CWELD Min (Strain A / Strain B) |
ELEMENT | SCALAR |
1D Stress CBAR Axial CBAR (SA1 / SA2, SA3, SA4) CBAR SA (Maximum / Minimum) CBAR Safety Margin (Compression / Tension) CBAR (SB1 / SB2 / SB3 / SB4) CBAR SB (Maximum / Minimum) CBEAM Long Stress at Point (C1 / C2) CBEAM Long Stress at Point (D1 / D2) CBEAM Long Stress at Point (E1 / E2) CBEAM Long Stress at Point (F1 / F2) CBEAM Maximum (Stress1 / Stress2) CBEAM Margin of Safety (Compression1 / Compression2) CBEAM Margin of Safety (Tension1 / Tension2) CBEAM Minimum (Stress1 / Stress2) CELAS Stress CROD Axial (Stress / Safety Margin) CROD Torsional (Stress / Safety Margin) CWELD Axial Stress CWELD Bearing Stress CWELD Max Shear Stress CWELD Max (Stress A / Stress B) CWELD Min (Stress A / Stress B) |
ELEMENT | SCALAR |
2D Force Membrane (x / y / xy) Bending (x / y / xy) trans_shear (x / y) |
ELEMENT | SCALAR |
CBEAM Forces4 CBEAM Axial Force CBEAM Bending Moment (Plane1 / Plane2) CBEAM Total Torque CBEAM Warping Torque CBEAM Web Shear (Plane1 / Plane2) |
ELEMENT | SCALAR |
CHBDYG Applied Load Forced Convection Free Convection Radiation Total |
ELEMENT | SCALAR |
Contact Pressure | NODE | SCALAR |
Contact Status | NODE | SCALAR |
Contact Stress Normal Stress Friction Stress 1 Friction Stress 2 |
NODE | SCALAR |
CSHEAR Force Force (4 to 1 / 2 to 1) Force (1 to 2 / 3 to 2) Force (2 to 3 / 4 to 3) Force (3 to 4 / 1 to 4) Kick Force on (1 / 2 / 3 / 4) Shear (12 / 23 / 34 / 41) |
ELEMENT | SCALAR |
CSHEAR Forces4 Corner Forces Kick Forces Shear Forces |
ELEMENT | SCALAR |
CSHEAR Strain Average shear Maximum shear Safety margin |
ELEMENT | SCALAR |
CSHEAR Stress Maximum shear Average shear Safety margin |
ELEMENT | SCALAR |
CWELD Force Axial Force Bending Moment (Plane1 A / Plane2 A) Bending Moment (Plane1 B / Plane2 B) Shear (Plane1 / Plane2) Torque |
ELEMENT | SCALAR |
CWELD Strain Axial Strain Max Shear Strain Max Strain (A / B) Min Strain (A / B) |
ELEMENT | SCALAR |
CWELD Stress Axial Stress Bearing Stress Max Shear Stress Max Stress (A / B) Min Stress (A / B) |
ELEMENT | SCALAR |
Damping Energy Damping Energy % of Total Energy Energy Density |
ELEMENT | SCALAR |
Direct Grid Point Stresses Mean Pressure Normal (x / y / z) Shearxy Shearyz Shearzx Vonmises |
NODE | SCALAR |
Direct Strain Firstprincipal Normal (x / y /z) Secondprincipal Shearangle Shearxy Shearyz Shearzx Thirdprincipal Vonmises |
ELEMENT | SCALAR |
Direct Stress Firstprincipal Normal (x / y / z) Secondprincipal Shearangle Shearxy Shearyz Shearzx Thirdprincipal Vonmises |
ELEMENT | SCALAR |
Failure Index For Direct Stress For Inter Laminar Stress |
ELEMENT | SCALAR |
Grid Temperatures | NODE | SCALAR |
Heat Flow Applied Load Convection Convection Coefficient Radiation Total |
ELEMENT | SCALAR |
Inter Laminar Strain Shear XZ Shear YZ |
ELEMENT | SCALAR |
Inter Laminar Stress Shear XZ Shear YZ |
ELEMENT | SCALAR |
Kinetic Energy Kinetic Energy % of Total Energy Energy Density |
ELEMENT | SCALAR |
Nonlinear Strain Creep Normal (x / y / z) Plastic Shearxy Shearyz Shearzx |
ELEMENT | SCALAR |
Nonlinear Stress Equivalent Normal (x / y / z) Shearxy Shearyz Shearzx |
ELEMENT | SCALAR |
Axisymmetric Strain Radial Azimuthal Axial Shear Stress Maximum Principal Maximum Shear Octahedral |
ELEMENT | SCALAR |
Axisymmetric Stress Radial Azimuthal Axial Shear Stress Maximum Principal Maximum Shear Octahedral |
ELEMENT | SCALAR |
Ply Thickness | ELEMENT | SCALAR |
Shell Thickness | ELEMENT | SCALAR |
Strain Energy Strain Energy % of total energy Energy density |
ELEMENT | SCALAR |
Temperature | NODE | SCALAR |
Contact Incremental Slide | NODE | VECTOR |
Contact Total Slide | NODE | VECTOR |
Bolt Axial Force | ELEMENT | SCALAR |
Bolt Shear Force | ELEMENT | SCALAR |
Bolt Bending Moment | ELEMENT | SCALAR |
Bolt Axial Strain | ELEMENT | SCALAR |
Applied Force | NODE | Vector |
Applied Moment | NODE | Vector |
Displacement | NODE | Vector |
Rotation | NODE | Vector |
Velocity - Translation | NODE | Vector |
Velocity - Rotation | NODE | Vector |
Acceleration - Translation | NODE | Vector |
Acceleration - Rotation | NODE | Vector |
SPC Force | NODE | Vector |
SPC Moment | NODE | Vector |
MPC Force | NODE | Vector |
MPC Moment | NODE | Vector |
Grid Point SPC Forces | NODE | Vector |
Grid Point SPC Moments | NODE | Vector |
Grid Point MPC Forces | NODE | Vector |
Grid Point MPC Moments | NODE | Vector |
Grid Point Applied Forces | NODE | Vector |
Grid Point Applied Moments | NODE | Vector |
Grid Point Summed Forces | NODE | Vector |
Grid Point Summed Moments | NODE | Vector |
Grid Point Element Forces | ELEMENT | Vector |
Grid Point Element Moments | ELEMENT | Vector |
Strain | ELEMENT | Tensor |
Stress | ELEMENT | Tensor |
NonlinearStress | ELEMENT | Tensor |
NonlinearStrain | ELEMENT | Tensor |
2D Element Force | ELEMENT | Tensor |
2D Element Moment | ELEMENT | Tensor |
Composite Stress | ELEMENT | Tensor |
Composite Strain | ELEMENT | Tensor |
InterLaminar Stress | ELEMENT | Scalar |
InterLaminar Strain | ELEMENT | Scalar |
Ply thickness | ELEMENT | Scalar |
TotalPly thickness | ELEMENT | Scalar |
Failure Index:for direct Stress | ELEMENT | Scalar |
Failure Index:for inter laminar Stress | ELEMENT | Scalar |
Strain Energy:Strain Energy | ELEMENT | Scalar |
Strain Energy:% of Total Energy | ELEMENT | Scalar |
Strain Energy:Energy Density | ELEMENT | Scalar |
Shell Thickness | ELEMENT | Scalar |
2D Force | ELEMENT | Scalar |
1D Force | ELEMENT | Scalar |
1D Stress | ELEMENT | Scalar |
1D Strain | ELEMENT | Scalar |
1D Element Forces | ELEMENT | Scalar |
1D Element Moments | ELEMENT | Scalar |
CBEAM Forces | ELEMENT | Scalar |
CWELD Forces | ELEMENT | Scalar |
CWELD Stress | ELEMENT | Scalar |
CWELD Strain | ELEMENT | Scalar |
1D NonLinear Stress | ELEMENT | Scalar |
1D NonLinear Strain | ELEMENT | Scalar |
Contact Forces | NODE | Vector |
Friction Forces | NODE | Vector |
Contact Status | NODE | Scalar |
Contact Status:Normal Stress | NODE | Scalar |
Contact Status:Friction Stress 1 | NODE | Scalar |
Contact Status:Friction Stress 2 | NODE | Scalar |
Direct Stress: normal-x,y,z, shear-xy,yz,zx | ELEMENT | Scalar |
Direct Strain: normal-x,y,z, shear-xy,yz,zx | ELEMENT | Scalar |
Direct Nonlinear Stress | ELEMENT | Scalar |
Direct Nonlinear Strain | ELEMENT | Scalar |
Kinetic Energy | ELEMENT | Scalar |
CBUSH Forces | ELEMENT | Scalar |
CBUSH Stress | ELEMENT | Scalar |
CFAST Forces | ELEMENT | Scalar |
CSHEAR Forces | ELEMENT | Scalar |
- 詳細については、要素力(ベクトルプロット)をご参照ください。
- グリッドポイントの要素力 / モーメントは、コーナーデータを含む要素結果としてHyperViewに読み取られます。コーナーデータ値は、指定された要素にある個々の節点グリッドポイントの力 / モーメントを表します。
- 詳細については、要素力(テンソルプロット)をご参照ください。
- CSHEAR力は、コーナーデータを含む要素結果としてHyperViewに読み取られます。コーナーデータ値は以下の値を表します:
- コーナー力:N1:力4→力1
- コーナー力:N2:力1→力2
- コーナー力:N3:力2→力3
- コーナー力:N4:力3→力4
- せん断力:N1:せん断41
- せん断力:N2:せん断12
- せん断力:N3:せん断23
- せん断力:N4:せん断34
- キック力:N1:キック1
- キック力:N2:キック2
- キック力:N3:キック3
- キック力:N4:キック4
- CBEAM力は、コーナーデータを含む要素結果としてHyperViewに読み取られます。コーナーデータ値は、指定された要素にある個々の節点グリッドポイントの力を表します。
OGPFB1 (Grid point force)
ブロックの結果:リーダーでは“SPC Forces”としてデータタイプが作成されます。このブロックには、SPC、MPC、適用した力 / モーメントなどの結果があります。OQG1 (SPC force)
ブロックの結果:リーダーでは“SPC Force”としてデータタイプが作成されます。このブロックには、SPCの力 / モーメントのデータのみがあります。
- HyperViewは、Nastran 2012で作成されたOP2結果ファイルの複合応力をサポートしています。
- HyperViewでは、周波数応答のOP2結果ファイルに記述したGPFORCE結果をサポートしています。
- HyperViewでは、オプションPARAM, POST, 1を指定して生成したOP2結果ファイルをサポートしています。
- HyperViewでは、PARAM, POST, -1に対して以下のデータブロック名をサポートしています。
- OQG1、OUGV1、OES1、OEF1、OSTR1、ONRGY1、OES1X。
- HyperViewでは、PARAM, POST, -2に対して以下のデータブロック名をサポートしています。
- OQG1、BOUGV1、OUGV1、OES1、OEF1、OSTR1、ONRGY1、OES1X。
- HyperViewでは、応力データタイプとひずみデータタイプに対して以下の要素タイプをサポートしています。
CQUAD (33)、CQUADR (82)、CTETRA (39)、CTRIAR(70)、CQUAD8 (64)、CHEXA (67)、CPENTA (68)、CTRIA3 (74)、
CTRIA6 (75)、CQUAD4(144)、CTRIAX6 (53)
コーナー応力とコーナーひずみについては、以下の要素タイプをサポートしています。
CQUAD8 (64)、CTRIA6 (75)、CQUAD4(144)、CTETRA (39)、CHEXA (67)、CPENTA (68)
- HyperViewでは、力データタイプに対して以下の要素タイプをサポートしています。
CROD(1)、CONROD(10)、CBEAM(2)、CELAS1(11)、CELAS2(12)、CGAP(38)、CBAR(34)、CQUAD4(33)、CTRIA3(74)、
CQUAD(64)、CQUADR(82)、CTRIA6(75)、CTRIAR(70)、CQUAD4(144)
- モード周波数応答問題(sol 103)の場合、シミュレーション名はMode # f #Hzです。
- HyperViewでは、ジオメトリに対して以下のデータブロック名をサポートしています。
GEOM1、GEOM1S、GEOM2、GEOM2S
HEX8(208)、HEX20(220)、PENTA6(206)、PENTA15(215)、TETRA4(204)、
TETRA10(210)、QUAD4(104)、TRIA3(103)、QUAD8(108)、TRIA6(106)、BAR(60)、
ROD(61)
- すべてのテンソル結果(2Dと3D)は、要素結果座標系で表示する必要があります。
- 選択した組み合わせの結果を抽出する場合は、外部変換機能であるHvTransを使用してh3dファイルを作成します。
Nastranモデルと結果ファイルの読み取り
機能 | HyperView – アニメーションウィンドウ |
モデルファイルを直接読み出し | DAT、NAS、BDF、OP2、XDB、H5 |
結果ファイルを直接読み出し | OP2、XDB、H5 |
変換された結果を読み出し | PCH(hmnast: HMRESおよびH3D) OP2 (hmnast02: HMRESおよびH3D) |
OP2とXDBのNastran結果フォーム | |
Nastranの重心結果 | Yes |
Nastranのコーナー結果 | Yes |
板厚のコンター | Yes |
座標系 | |
アプリケーション内で別の座標系に結果を変換 | Yes |
任意のテンソルをベクトル結果に変換 | Yes |
