RMS2
Model ElementComputes the root mean square area difference between a measured signal and a target curve.
Class Name
RMS2
is the
measured signal.
is the target curve.
Attribute Summary
| Name | Property | Modifiable by Command? | Designable? |
| label | Str () | ||
| targetValue | Tuple () | Yes | |
| measuredValue | Function () | Yes | Yes |
Usage
# RMS2 defined as the area between a measured expression and a target curve
RMS2 (measuredValue=expressionString, targetValue=listOfXYTuples, optional_attributes)
Attributes
- measuredValue
- String
- targetValue
- Tuple of tuples.
- label
- String
# RMS2 measure of a Marker's X displacement with time vs a target curve
targetValue = ((0.00, 400.000),
(0.10, 382.665),
(0.20, 312.589),
(0.30, 211.853),
(0.40, 115.093),
(0.50, 53.181),
(0.60, 46.368),
(0.70, 113.983),
(0.80, 275.874),
(0.90, 369.449),
(1.00, 400.001))
measuredValue = "DX({id})".format(id=model.coupler.cm.id)
rms2 = RMS2 (label="DX", targetValue=targetValue, measuredValue=measuredValue)
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
