CACPML3
Bulk Data Entry Defines an acoustic Adaptive Perfectly Matched Layer (APML) element with a triangular base.
| CACPML3 | EID | PID | G1 | G2 | G3 |
| CACPML3 | 7 | 1 | 123 | 225 | 9991 |
| Field | Contents | SI UnitExample |
| EID | Unique element identification number. No default (Integer > 0) |
| PID | PACPML property entry
| G1, G2, G3 | Grid point identification numbers of element base connection
points. No default (Integer > 0) |
- This element should be connected to acoustic grid points. These elements form the surface of the APML layer on top of an acoustic domain.
- A 4-noded formulation of this element, CACPML4 is also available.
- For more information, refer to Acoustic Adaptive Perfectly Matched Layer (APML) in the User Guide.
