MATF3
Bulk Data Entry Specifies frequency-dependent material properties on MAT3 entry fields via TABLEDi entries.
MATF3 | MID | T(EX) | T(ETH) | T(EZ) | T(NUXTH) | T(NUTHZ) | T(NUZX) | T(RHO) | |
T(GZX) | T(AX) | T(ATH) | T(AZ) | T(GE) |
MATF3 | 17 | 32 | 19 | ||||||
52 |
MID | Material property identification number that
matches the identification number on the
MAT3 entry. (Integer > 0) |
T(EX), T(ETH), T(EZ) | TABLEDi entry identification numbers for Young's moduli in the
x,
θθ
and z directions. Default = blank (Integer ≥ 0 or blank) |
T(NUXTH), T(NUTHZ), T(NUZX) | TABLEDi entry identification numbers for Poisson's ratios in
the x
θ
θ
z and zx directions. Default = blank (Integer ≥ 0 or blank) |
T(RHO) | A
TABLEDi entry identification number for the mass
density. Default = blank (Integer ≥ 0 or blank) |
T(GZX) | A
TABLEDi entry identification number for the shear
modulus. Default = blank (Integer ≥ 0 or blank) |
T(AX), T(ATH), T(AZ) | TABLEDi entry identification numbers for thermal expansion
coefficients in the x,
θ
and z directions. Default = blank (Integer or blank) |
T(GE) | A
TABLEDi entry identification number for the damping
coefficient. Default = blank (Integer > 0 or blank) |
- Fields 3, 4, and so on of this entry correspond, field-by-field, to fields 3, 4, and so on of the MAT3 entry referenced in field 2. The value in a particular field of the MAT3 entry is replaced or modified by the table referenced in the corresponding field of this entry. In the example, EX is modified; TABLEDi 32, RHO is modified by TABLEDi 19; and GE is modified by TABLEDi 52.
- Blank or zero entries mean that there is no frequency dependence of the field on the MAT3 entry. Any quantity modified by this entry must have a value on the MAT3 entry.
- In Modal Frequency Response Analysis, the frequency-dependency is only used in the frequency response part of the solution, not in the modal analysis part of the solution.
- This card is represented as a material in HyperMesh.
