CHARGE
Bulk Data Entry Defines a point electric charge at a grid or a set of grids.
| CHARGE | SID | GID/GSETID | VALUE | ||||||
| GSET |
| CHARGE | 2 | 5 | 2.3 |
| SID | Load identification
number. No default (Integer > 0) |
| GID/GSETID |
| VALUE | The magnitude of the point
electric charge. No default (Real) |
| GSET | Flag to indicate that the GID/GSETID field is identified as a SET of grid points at which the charge is applied. |
- For more information, refer to Piezoelectric Analysis in the User Guide.
