PCONTX
Bulk Data Entry Defines properties of a CONTACT interface for geometric nonlinear analysis.
PCONTX | PID | STFAC | FRIC | GAP | IDEL | INACTI | CTYPE | ||
TSTART | TEND | ||||||||
ISYM | IEDGE | FANG | IGAP | ISTF | STIF1 | STMIN | STMAX | ||
VISS | VISF | BMULT | IBC | MULTIMP | |||||
IFRIC | IFORM | IFILTR | FFAC | ||||||
C1 | C2 | C3 | C4 | C5 | C6 |
PCONT | 34 | ||||||||
PCONTX | 34 |
PID | Property
identification number of the associated PCONT. No default (Integer > 0) |
STFAC | Interface stiffness
scale factor. Default as defined by CONTPRM (Real ≥ 0) |
FRIC | Coulomb
friction. Default as defined by CONTPRM (Real ≥ 0) |
GAP | Gap for impact
activation. 4
9 Default as defined by CONTPRM (Real ≥ 0) |
IDEL | Flag for node and
segment deletion.
Default as defined by CONTPRM (Integer = 0, 1, or 2) |
INACTI | Handling of initial
penetrations flag. 11
Default as defined by CONTPRM (Integer = 0, ..., 5) Valid in explicit analysis: 0, 1, 2, 3 and 5. Valid in implicit analysis: 0, 3 and 4. Invalid entries are ignored. |
CTYPE | Implicit contact
type. Default = TYPE7 (Character = TYPE5 or TYPE7) |
TSTART | Start time Default = 0.0 (Real ≥ 0) |
TEND | Time for temporary
deactivation. Default = 1030 (Real ≥ 0) |
The following entries are relevant for explicit analysis only. | ||
ISYM | Symmetric contact flag.
If SSID defines a grid set, the contact is always a main-secondary contact. Default as defined by CONTPRM (Character = SYM or UNSYM) |
IEDGE | Flag for edge
generation from secondary and main surfaces.
Default as defined by CONTPRM (Character = NO, ALL, BORD, or FEAT) |
FANG | Feature angle for edge
generation (Only with IEDGE = FEAT). Default as defined by CONTPRM (Real ≥ 0) |
IGAP | Gap definition flag.
Default as defined by CONTPRM (Character = CONST or VAR) |
ISTF | Stiffness definition
flag. 5
Default as defined by CONTPRM (Integer = 0, ..., 5) |
STIF1 | Interface stiffness
(Only with ISTF =
1) Default = 0.0 (Real ≥ 0) |
STMIN | Minimum stiffness
(Only with ISTF > 1). Default as defined by CONTPRM (Real ≥ 0) |
STMAX | Maximum stiffness
IBC | Flag for deactivation
of boundary conditions at impact applied to the secondary grid
set. Default as defined by CONTPRM (Character = X, Y, Z, XY, XZ, YZ, or XYZ) |
MULTIMP | Maximum average number
of impacted main segments per secondary node. Default = 4 for SMP; 12 for SPMD (Integer > 0) |
VISS | Critical damping
coefficient on interface stiffness. Default as defined by CONTPRM (Real ≥ 0) |
VISF | Critical damping
coefficient on interface friction. Default as defined by CONTPRM (Real ≥ 0) |
BMULT | Sorting factor. Can be
used to speed up the sorting algorithm. Is
machine-dependent. Default as defined by CONTPRM (Real ≥ 0) |
IFRIC | Friction formulation
flag. 12
Default as defined by CONTPRM (Character = COUL, GEN, DARM, or REN) |
IFORM | Friction penalty
formulation type. 13
Default as defined by CONTPRM (Character = VISC or STIFF) |
IFILTR | Friction filtering
flag. 14
Default as defined by CONTPRM (Character = NO, SIMP, PER, or CUTF) |
FFAC | Friction filtering
factor. Default as defined by CONTPRM (Real = 0.0 ≤ FFAC < 1.0) |
C1, C2, C3, C4, C5, C6 | Coefficients to define
variable friction coefficient in IFRIC = GEN, DARM, or
REN. Default as defined by CONTPRM (Real ≥ 0) |
- The property identification number must be that of an existing PCONT Bulk Data Entry. Only one PCONTX property extension can be associated with a particular PCONT.
- PCONTX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- If FRIC is not explicitly defined on the PCONTX/PCNTX# entries, the MU1 value on the CONTACT or PCONT entry is used for FRIC in the /INTER entries for Geometric Nonlinear Analysis. Otherwise, FRIC on PCONTX/PCNTX# overwrites the MU1 value on CONTACT/PCONT.
- In implicit analysis, different contact
formulations are used for contact where secondary and main set do not overlap
and where they overlap (self-contact).
In the case of self-contact, the gap cannot be zero and a constant gap is used. For small initial gaps, the convergence will be more stable and faster if GAP is larger than the initial gap.
In implicit analysis, sometimes a stiffness with scaling factor reduction (for example, STFAC = 0.01) or reduction in impacted thickness (if rigid one) might reduce unbalanced forces and improve convergence, particularly in shell structures under bending where the effective stiffness is much lower than membrane stiffness; but it should be noted that too low of a value could also lead to divergence.
- If ISTF ≠ 1, the interface stiffness K is computed from the main
segment stiffness Km and/or the secondary segment stiffness Ks.
The main stiffness is computed from Km = STFAC * B * S * S/V for solids, Km = 0.5 * STFAC * E * t for shells.
The secondary stiffness is an equivalent nodal stiffness computed as Ks = STFAC * B * V-3 for solids, Ks = 0.5 * STFAC * E * t for shells.
In these equations, B is the Bulk Modulus, S is the segment area, and V is the volume of a solid. There is no limitation to the value of stiffness factor (but a value larger than 1.0 can reduce the initial time step).
The interface stiffness is K = max (STMIN, min (STMAX, K1)) with- ISTF = 0, K1 = Km
- ISTF = 2, K1 = 0.5 * (Km + Ks)
- ISTF = 3, K1 = max (Km, Ks)
- ISTF = 4, K1 = min (Km, Ks)
- ISTF = 5, K1 = Km * Ks / (Km + Ks)
- The default for the constant gap (IGAP = CONST) is the minimum of
- t, average thickness of the main shell elements
- l/10, l - average side length of the main solid elements
- lmin/2, lmin - smallest side length of all main segments (shell or solid)
- The variable gap (IGAP = VAR) is computed as gs + gm with:
- gm - main element gap with
gm = t/2, t: thickness of the main element for shell elements.
gm = 0 for solid elements.
- gs - secondary node gap:
gs = 0 if the secondary node is not connected to any element or is only connected to solid or spring elements.
gs = t/2, t - largest thickness of the shell elements connected to the secondary node.
gs = 1/2✓S for truss and beam elements, with S being the cross-section of the element.
If the secondary node is connected to multiple shells and/or beams or trusses, the largest computed secondary gap is used.
- INACTI = 3, 4 are only recommended for small
initial penetrations and should be used with caution because:
- the coordinate change is irreversible.
- it may create other initial penetrations if several surface layers are defined in the interfaces.
- it may create initial energy if the node belongs to a spring element.
INACTI = 5 works as:
Figure 1. - IFRIC defines the friction model.
IFRIC = COUL - Coulomb friction with FT ≤ FRIC * FN.
For IFRIC > 0 the friction coefficient is set by a function ( = (p, V)), where p is the pressure of the normal force on the main segment and V is the tangential velocity of the secondary node.
The following formulations are available:- IFRIC = 1 - Generalized viscous friction
law
(1) - IFRIC = 2 - Darmstad law
(2) - IFRIC = 3 - Renard law
0 ≤ V ≤ C5 C5 ≤ V ≤ C6 C6 ≤ V where:(3) - The first critical velocity Vcr1 must not be 0 (C5 ≠ 0). It also must be lower than the second critical velocity Vcr2 (C5 < C6).
- The static friction coefficient C1 and the dynamic friction coefficient C2, must be lower than the maximum friction C3 (C1 ≤ C3) and C2 ≤ C3).
- The minimum friction coefficient C4, must be lower than the static friction coefficient C1 and the dynamic friction coefficient C2 (C4 ≤ C1 and C4 ≤ C2).
law
- IFORM selects two types of contact friction penalty formulation. The viscous (total) formulation (IFORM = VISC) computes an adhesive force as:
(4) The stiffness (incremental) formulation (IFORM = STIFF) computes an adhesive force as:(5) - IFILTR defines the method for computing the friction filtering coefficient. If IFILTR ≠ NO, the tangential friction forces are smoothed using a
filter:
(6) Where,
FT is the tangential force
F'T is the tangential force at time t
F'T-1 is the tangential force at time t-1
α is the filtering coefficient
IFILTR = SIMP conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" /> = FFAC
IFILTR = PER conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" /> = 2πdt/FFAC, where dt/T = FFAC, T is the filtering period
IFILTR = CUTF conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" /> = 2π * FFAC * dt, where FFAC is the cutting frequency
- This card is represented as an extension to a PCONT property in HyperMesh.
