PCNTX7
Bulk Data Entry Defines properties TYPE7 of a CONTACT interface for geometric nonlinear analysis.
PCNTX7 | PID | ||||||||
ISTF | ITHE | IGAP | IBAG | IDEL | ICURV | IADM | |||
GAPFAC | GAPMAX | FPENMAX | |||||||
STMIN | STMAX | MESHSIZE | DTMIN | IREMGAP | |||||
STFAC | FRIC | GAP | TSTART | TEND | |||||
IBC | INACTI | VISS | VISF | BMULT | |||||
IFRIC | IFILTR | FFAC | IFORM | SENSID | |||||
CURVDAT | G1 | G2 | |||||||
FRICDAT | C1 | C2 | C3 | C4 | C5 | C6 | |||
ADMDAT | NRADM | PADM | ANGLADM | ||||||
THEDAT | RTHE | TINT | ITHEF | ||||||
FRAD | DRAD | FHEATS | FHEATM |
PCONT | 34 | ||||||||
PCNTX7 | 34 |
PID | Property identification number of the associated PCONT. No default (Integer > 0) |
ISTF | Stiffness definition flag. 5
Default as defined by CONTPRM (Integer = 0, ..., 5) |
ITHE | Heat
contact flag.
(Integer) |
IGAP | Gap
definition flag.
Default as defined by CONTPRM (Character = CONST, VAR, VAR2, or VAR3) |
IBAG | Airbag vent holes closure flag in case of contact.
(Integer) |
IDEL | Node
and segment deletion flag.
Default as defined by CONTPRM (Integer) |
ICURV | Gap
envelope with curvature. 8
(Integer) |
IADM | Computing local curvature flag for adaptive meshing. 9
10
(Integer) |
GAPFAC | Gap
scale factor (used only when IGAP = VAR2 and VAR3). Default as defined by CONTPRM (Real ≥ 0) |
GAPMAX | Maximum gap (used only when IGAP = VAR2 and VAR3).
FPENMAX | Maximum fraction of initial penetration. 12 (Real) |
STMIN | Minimum stiffness (Only with ISTF > 1). Default as defined by CONTPRM (Real ≥ 0) |
STMAX | Maximum stiffness (Only with ISTF > 1). Default as defined by CONTPRM (Real ≥ 0) |
MESHSIZE | Percentage of mesh size (used only when
IGAP =
VAR3). Default = 0.4 (Real, 0.0 < MESHSIZE ≤ 1.0) |
DTMIN | Limiting nodal time step. 18 | |
IREMGAP | Flag
to deactivate secondary nodes if element size < gap value, in case of self-impact
contact. 19
(Integer) |
STFAC | Interface stiffness scale factor. Default as defined by CONTPRM (Real ≥ 0) |
FRIC | Coulomb friction. Default as defined by CONTPRM (Real ≥ 0) |
GAP | Gap
for impact activation. 4
6 Default as defined by CONTPRM (Real ≥ 0) |
TSTART | Start time. Default = 0.0 (Real ≥ 0) |
TEND | Time
for temporary deactivation. Default = 1030 (Real ≥ 0) |
IBC | Flag
for deactivation of boundary conditions at impact applied to the secondary grid
set. Default as defined by CONTPRM (Character = X, Y, Z, XY, XZ, YZ, or XYZ) |
INACTI | Handling of initial penetrations flag. 12
Invalid entries are ignored. Default as defined by CONTPRM (Integer) |
VISS | Critical damping coefficient on interface
stiffness. Default as defined by CONTPRM (Real ≥ 0) |
VISF | Critical damping coefficient on interface
BMULT | Sorting factor. Can be used to speed up the
sorting algorithm. Is machine-dependent. Default as defined by CONTPRM (Real ≥ 0) |
IFRIC | Friction formulation flag. 13
Default as defined by CONTPRM (Character) |
IFILTR | Friction filtering flag. 14
FFAC | Friction filtering factor. Default as defined by CONTPRM (Real = 0.0 ≤ FFAC < 1.0) |
IFORM | Friction penalty formulation type. 15
SENSID | Sensor identifier to activate/deactivate the interface. 20 No default (Integer) If a sensor identifier is defined, the activation/deactivation of the interface is based on SENSID instead of TSTART or TSTOP. |
CURVDAT | Indicates that additional information about ICURV will follow. Only available when ICURV = 1 or 2. | |
G1 | First grid identifier (used only when ICURV = 1 or 2). (Integer) |
G2 | Second grid identifier (used only when ICURV = 2, ignored when ICURV = 1). (Integer) |
FRICDAT | Indicates that additional information for IFRIC will follow. Only available when IFRIC = GEN, DARM or REN. | |
C1, C2, C3, C4, C5, C6 | Coefficients to define variable friction coefficient in IFRIC = GEN, DARM, or REN. Default as defined by CONTPRM (Real ≥ 0) |
ADMDAT | Indicates that additional information about IADM will follow. Only available when IADM = 2. | |
NRADM | Number of elements through a 90 degree radius (used only when IADM = 2). (Integer) |
PADM | Criteria on the percentage of penetration (used only when IADM = 2). Default = 1.0 (Real) |
ANGLADM | Angle criteria (used only when IADM = 2). (Real) |
THEDAT | Indicates that additional information about ITHE will follow. Only available when ITHE = 1. | |
RTHE | Heat
conduction coefficient (used only when ITHE = 1). 17 (Real) |
TINT | Interface temperature (used only when ITHE = 1). (Real) |
ITHEF | Heat
contact formulation flag (used only when ITHE = 1, Integer).
FRAD | Radiation factor (used only when ITHE = 1). No default (Real) |
DRAD | Maximum distance for radiation computation (used only when ITHE = 1). A very high value of DRAD is not recommended as it may reduce the performance of the solver. No default (Real) |
FHEATS | Frictional heating factor of the secondary (used only when ITHE = 1). 23 No default (Real) |
FHEATM | Frictional heating factor of the main (used only when ITHE = 1). 23 No default (Real) |
- The property identification number must be that of an existing PCONT Bulk Data Entry. Only one PCNTX7 property extension can be associated with a particular PCONT.
- PCNTX7 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- If FRIC is not explicitly defined on the PCONTX/PCNTX# entries, the MU1 value on the CONTACT or PCONT entry is used for FRIC in the /INTER entries for Geometric Nonlinear Analysis. Otherwise, FRIC on PCONTX/PCNTX# overwrites the MU1 value on CONTACT/PCONT.
- In
implicit analysis, different contact formulations are used for contact where secondary and
main set do not overlap and where they overlap (self-contact).
In the case of self-contact, the gap cannot be zero and a constant gap is used. For small initial gaps, the convergence will be more stable and faster if GAP is larger than the initial gap.
In implicit analysis, sometimes a stiffness with scaling factor reduction (for example, STFAC = 0.01) or reduction in impacted thickness (if rigid one) might reduce unbalanced forces and improve convergence, particularly in shell structures under bending where the effective stiffness is much lower than membrane stiffness; but it should be noted that too low of a value could also lead to divergence.
- If ISTF
≠ 1, the interface stiffness K is computed from the main segment stiffness Km and/or the
secondary segment stiffness Ks.
The main stiffness is computed from Km = STFAC * B * S * S/V for solids, Km = 0.5 * STFAC * E * t for shells.
The secondary stiffness is an equivalent nodal stiffness computed as Ks = STFAC * B * V-3 for solids, Ks = 0.5 * STFAC * E * t for shells.
In these equations, B is the Bulk Modulus, S is the segment area, and V is the volume of a solid. There is no limitation to the value of stiffness factor (but a value larger than 1.0 can reduce the initial time step).
The interface stiffness is then K = max (STMIN, min (STMAX, K1)) with:- ISTF = 0, K1 = Km
- ISTF = 2, K1 = 0.5 * (Km + Ks)
- ISTF = 3, K1 = max (Km, Ks)
- ISTF = 4, K1 = min (Km, Ks)
- ISTF = 5, K1 = Km * Ks / (Km + Ks)
- The
default for the constant gap (IGAP
= CONST) is the minimum of:
- t, average thickness of the main shell elements
- l/10, l - average side length of the main solid elements
- lmin/2, lmin - smallest side length of all main segments (shell or solid)
- If IGAP
= VAR, the variable gap is computed as gs + gm
If IGAP = VAR2, the variable gap is computed as max(GAP, min(GAPFAC * (gs+gm), GAPMAX)
If IGAP = VAR3, the variable gap is computed as max(GAP, min(GAPFAC * (gs+gm), MESHSIZE * (gsl+gml), GAPMAX)
with:- gm - main element gap, with:
gm = t/2, t: thickness of the main element for shell elements.
gm = 0 for solid elements.
- gs - secondary node gap:
gs = 0 if the secondary node is not connected to any element or is only connected to solid or spring elements.
gs = t/2, t - largest thickness of the shell elements connected to the secondary node.
gs = 1/2√S for truss and beam elements, with S being the cross-section of the element.
- gml - length of the smaller edge of element.
- gsl - length of the smaller edge of elements connected to the secondary nodes.
If the secondary node is connected to multiple shells and/or beams or trusses, the largest computed secondary gap is used.
The variable gap is always at least equal to GAP.
- If ICURV = 1, a spherical curvature is defined for the gap with node_ID1 (center of the sphere).
If ICURV = 2, a cylindrical curvature is defined for the gap with node_ID1 and node_ID2 (on the axis of the cylinder).
If ICURV = 3, the main surface shape is obtained with a bicubic interpolation, respecting continuity of the coordinates and the normal from one segment to the other.
In case of a large change in curvature, this formulation might become unstable (will be improved in future version).
Figure 1. - In
case of adaptive meshing and IADM
=1: If the contact occurs in a zone (main side) whose radius of curvature is lower than the element size (secondary side), the element on the secondary side will be divided (if not yet at maximum level).
Figure 2. - In
=2:
If the contact occurs in a zone (main side) whose radius of curvature is lower than NRadm times the element size (secondary side), the element on the secondary side will be divided (if not yet at maximum level).
If the contact occurs in a zone (main side) where the angles between the normals are greater than Angladm and the percentage of penetration is greater than Padm, the element on the secondary side will be divided (if not yet at maximum level).
Figure 3. - The coefficients NRADM, PADM, and ANGLADM are used only adaptive meshing and IADM = 2.
- INACTI
= 3, is only recommended for small initial penetrations and should be
used with caution because:
- the coordinate change is irreversible
- it may create other initial penetrations if several surface layers are defined in the interfaces
- it may create initial energy if the node belongs to a spring element
INACTI = 5 is recommended for airbag simulation deployment.
INACTI = 6 is recommended instead of INACTI = 5, in order to avoid high frequency effects into the interfaces.
Figure 4.If FPENMAX is not equal to zero, nodes stiffness is deactivated if penetration > FPENMAX*GAP, regardless of the value of INACTI.
- IFRIC
defines the friction model.
IFRIC = COUL - Coulomb friction with FT < FRIC * FN.
For IFRIC > 0 the friction coefficient is set by a function ( = (p, V)), where p is the pressure of the normal force on the main segment and V is the tangential velocity of the secondary node.
The following formulations are available:- IFRIC = 1 - Generalized viscous friction law
(1) - IFRIC = 2 - Darmstad law
(2) - IFRIC = 3 - Renard law
0 ≤ V ≤ C5 C5 ≤ V ≤ C6 C6 ≤ V Where,
(3) - The first critical velocity Vcr1 must not be 0 (C5 ≠ 0). It also must be lower than the second critical velocity Vcr2 (C5 < C6).
- The static friction coefficient C1 and the dynamic friction coefficient C2, must be lower than the maximum friction C3 (C1 ≤ C3) and C2 ≤ C3).
- The minimum friction coefficient C4, must be lower than the static friction coefficient C1 and the dynamic friction coefficient C2 (C4≤ C1 and C4 ≤ C2).
- IFILTR defines the method for computing the friction filtering coefficient. If
IFILT ≠ NO, the tangential friction forces are
smoothed using a filter:
(4) Where,- FT
- Tangential force
- F'T
- Tangential force at time t
- F'T-1
- Tangential force at time t-1
- α
- Filtering coefficient
- IFILTR = SIMP conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx7_bulk_r_ph_dmj_vtb_k1b"/> = FFAC
- IFILTR = PER conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx7_bulk_r_ph_dwt_vtb_k1b"/> = 2πdt/FFAC, where dt/T = FFAC, T is the filtering period
- IFILTR = CUTF conref="../../bank/solvers_symbols_equations_r_b.dita#reference_xh2_vkk_pw/o2_sym_alpha" id="pcntx7_bulk_r_ph_stz_vtb_k1b"/> = 2π * FFAC * dt, where FFAC is the cutting frequency
- IFORM
selects two types of contact friction penalty formulation.The viscous (total) formulation (IFORM = VISC) computes an adhesive force as:
(5) The stiffness (incremental) formulation (IFORM = STIFF) computes an adhesive force as:(6) - Exchange between shell and constant temperature contact TINT.
- RTHE is the inverse of thermal resistance (units: [W/(m2*K)]).
- Secondary segment contact is deactivated when the segment kinematic time step calculated for this contact is lower than DTMIN.
- With
IREMGAP = 2, this allows the element size < gap
values:
Figure 5.In case of self-impact contact, when curvilinear distance (from a node of the main segment to a secondary node) is < gap*sqrt(2) (in initial configuration), then this secondary node will not be taken into account by this main segment, and it will not be deleted from the contact for the other main segments.
- When SENSID is defined for activation/deactivation of the interface, TSTART and TSTOP are not taken into account.
- If
FRAD
is not equal to zero, and d, the distance from the secondary node to the main segment, is
in the range: Gap < d < DRAD,
then radiation is calculated. The radiant heat transfer conductance is calculated
as:
(7) (8) Where,- Stefan Boltzman constant
- Emissivity of the secondary surface
- Emissivity of the main surface
- If
FRAD
is not equals to zero, then the default value of DRAD
is calculated as the maximum of:
- upper value of the gap (at time 0) among all nodes
- smallest side length of secondary element
- Frictional energy is converted into heat when heat transfer is activated (ITHE
> 0) on the interface. Options FHEATS and
FHEATM are used to control this option.
When FHEATS and FHEATM = 0, the conversion of the frictional sliding energy to heat is not activated. Non-zero values of FHEATS and FHEATM define the fraction of this energy which is converted into heat and transferred to the secondary and main, respectively.
The frictional heat QFric is defined as:
If IFORM = 2 (a stiffness formulation):- Secondary:
(9) - Main:
(10) (ITHEF=1)
If IFORM = 1 (a penalty formulation):- Secondary:
(11) - Main:
(12) (ITHEF=1)
- Secondary:
- This card is represented as an extension to a PCONT property in HyperMesh.
