MATTPZO
Bulk Data Entry Defines temperature-dependent coupling terms between structural and dielectric materials, for defining a piezoelectric coupling.
| MATTPZO | MID | T(PIEZO11) | T(PIEZO12) | T(PIEZO13) | T(PIEZO14) | T(PIEZO15) | T(PIEZO16) | ||
| T(PIEZO21) | T(PIEZO22) | T(PIEZO23) | T(PIEZO24) | T(PIEZO25) | T(PIEZO26) | ||||
| T(PIEZO31) | T(PIEZO32) | T(PIEZO33) | T(PIEZO34) | T(PIEZO35) | T(PIEZO36) |
| MATTPZO | 1 | 1011 | 1014 | 1016 | |||||
| 1022 | |||||||||
| 1033 |
| MID | Material property
identification number. Must match the identification number on MATPZO Bulk Data Entry. No default (Integer > 0) |
| T(PIEZOij) | Identification number of
the TABLEM1-4 or TABLEG Bulk Data Entries that defines the
individual elements of the temperature-dependent piezoelectric
coupling matrix. Default = blank (Integer > 0) |
- The quantities defined on the MATPZO Bulk Data Entry are multiplied by the tabular function referenced by the MATTPZO Bulk Data Entry to generate the corresponding material properties.
- If the fields are blank or zero, then constant properties defined on the MATPZO Bulk Data Entry are used.
- For more information, refer to Piezoelectric Analysis in the User Guide.
